Shock Extenders - 2 inch drop shackle
Old May 7, 2010 | 11:07 PM
stevenc's Avatar
Default Shock Extenders - 2 inch drop shackle
Should I do them to improve ride quality?
will these work?
http://www.stylintrucks.com/part.asp...7&scid=FROOGLE
says 3 inch drop on another site.
Old May 8, 2010 | 12:25 AM
00ChevyScott's Avatar
Wearin' da big hat
You shouldn't need to do that just with drop shackles. They rarely drop a full 2" anyways.
The only thing you might wanna check is your pinion angle, sometimes it can be a problem after changing hangers.
Old May 10, 2010 | 07:25 AM
dhpro's Avatar
Im just dealing with the trailing arm drop shackles...but as I have 4 link it shortens the driveline and can pinch the pinion/bearing/tranny seal. Traction is great out of the hole, but all the angles get messy. As I had an aftermarket diff cover and sway, it made for clearance probs (I put shorter sway end links to put the sway back to horizontal and stiffen further) too and the went back to stock cover. I also elected to take the shackles off instead of shortening/getting new d-shaft.
GMCSIERRA5.3
Aug 7, 2015 01:50 AM
shupe
Aug 5, 2015 06:45 PM
LoneSStar
Jul 27, 2015 09:27 PM
DONTH8
Jul 26, 2015 06:59 PM
Ammadien
Jul 22, 2015 08:50 PM
