Shift Cable Adjustment??
Is there any way to adjust the shift cable? I am buttoning up my 4L80 swap and the cable seems to be short and will not place the gear selector all the way in park. Without being attached to the selector on the trans, running the cable thru the gear positions and back to park, the cable attachment seems to be about 3/4" shy of the selector. I can pull the cable to within 1/4" of the selector and can even attach it but as soon as the column shifter is moved down into a selected gear, it will not go back in park without getting under the truck and manualy pushing the trans selector into park position. Anyone else ran across this with their 80 swaps?
High on diesel fumes
The place where the two halves of the cable connect can be adjusted. It's along the outside of the driver's side frame rail. There's one piece spring loaded that you pull back, then there's a blue clip underneath that you can pop partway off and adjust the cable.
Had a buddy pull the procedure from AllData and send it to me. Looks pretty simple as the cable is self adjusting.
-With all connections made, shift lever at column and transmission in park position, pull back white cover on intermediate cable connector, pull up on center tabs on neutral colored lock.
-push two cable halves together untill inner blue spring is completely compressed then release allowing blue spring to tension/adjust cable.
-push down lock and push back white cover conceling neutral colored lock.
-test gear selection. If all gears are not acheived, repeat procedure.
Looks like I need a new cable. As I was fooling with it, it got harder and harder to shift and eventually move but from reverse to neutral. I took the whole cable out and it feels like something in the upper cable is binding. The cable is supposed to be two pieces but mine looks like only one. The part number on mine does not look like a good part number either.
