Shackles help!
Old Mar 20, 2010 | 01:34 PM
MuzaK's Avatar
Registered User
Default Shackles help!
Ok, so the guy who was helping me install the shackels decided to put the jack and towers on the differential instead of the frame, and then he unhooked the stock shackle from the bottom(since u cant do it from the top because of the metal sheet), but now the leafspring lowerd and the shackle is pressed up against the bed underneath.Now we have to put the towers on the frame(as i told him b4 we began). So pretty much what i am asking is, did u guys have to take off the leaf spring to install the shackles on the NNBS and what are the best ways to go about finish this job in which i just described to all of you.
Old Mar 20, 2010 | 01:59 PM
95 bright teal's Avatar
support the frame of the truck
put jack under differential, lift rear slightly remove bolts from one shackle, use jack to line up holes put the bolts back in.
repeat for other side
FlyingLow
Nov 24, 2015 10:05 AM
dhorner77
Sep 11, 2015 05:10 PM
LPCWS6
Sep 1, 2015 10:03 PM
Darknight-4
Sep 1, 2015 05:50 PM
signguy62
Jul 27, 2015 03:42 PM
