Servo Install Problems
Old Sep 30, 2006 | 12:01 PM
Phantom's Avatar
11 Second Club
Default Servo Install Problems
I installed the vette servo and a billet 4th servo on my pick-up this morning. I also have the hd-2 shift kit waiting to be installed. I figured while I had the servos out i would put the new blue cushion spring in that comes with the shift kit. Got everything put back together so I could take it for drive before I go to work but 1-2 is not very firm, and between 2-3 it feels like it slipping/surging and i have to let off for it to shift. Thats when I'm all over it anyways. Just driving normal it seems to be ok. Any ideas for me here?
Old Sep 30, 2006 | 05:39 PM
icedenali's Avatar
how's your 3rd to 4th feel like? because i got my 4th super billet and saw only about 100 rpm between 3rd to 4th. I think you need tune to fix that problem.
Old Sep 30, 2006 | 06:00 PM
Phantom's Avatar
11 Second Club
I'm not real sure on the 3-4. But between 2-3 is what worries me. Took it apart but the pen did not fall out like it did when i took the stock stuff out. Not real sure whats goin on...I'm going to take all apart again and put the vette servo in then put stock 4th servo in and see what happens
Old Sep 30, 2006 | 06:43 PM
icedenali's Avatar
i think 4th servo has nothing to do with between 2-3 shift
what tranny do you have 4l60 or 4l65?
Old Sep 30, 2006 | 11:45 PM
Phantom's Avatar
11 Second Club
Well its not lookin good for the home team. Can't move vette servo or pin at all
Old Sep 30, 2006 | 11:59 PM
FLT's Avatar
FLT
FormerVendor
Maybe you cut a ring and that's why it's stuck. Try getting a screw driver in there and pry against the washer. It should pop out. Let us know if you need some seals.Vince.
Old Oct 1, 2006 | 12:11 AM
Phantom's Avatar
11 Second Club
Well I pried for a little bit then i took the e-clip, washer and spring off. I'm thinking thats what happened is i cut an o-ring but i can't get that damn servo out for nothing...Luckily i've got a couple for o-rings...Why won't the pin come out though?
Old Oct 1, 2006 | 12:18 AM
FLT's Avatar
FLT
FormerVendor
I think that you cut one of the teflon rings on the servo and it's jammed the servo in there along with the pin. I would put the washer and clip back on and pry some more. Vince
Old Oct 1, 2006 | 12:24 AM
Phantom's Avatar
11 Second Club
Dude i really appreciate your help and that kind of lifts my spirits...I'll give it a go in the morning...how much can i pry without breakin something?
Old Oct 1, 2006 | 01:06 AM
FLT's Avatar
FLT
FormerVendor
I guess until it comes out or you break something! Lets hope it comes out. Maybe if it wont come out when leaning on it a little try tapping on it a little to straighten it out. You could try to blow it out of there but that would reguire dropping the valve body again and a compressor. There is a check ball that is in the case in the servo area. This is where the release oil is. You could also try prying in the front of the case between the pump and valve body. If you look up into the case you can se the band and might be able pry it there as well. Good luck,Vince.
