S10 calipers to fit 15s
Bought s10 calipers and reused my disc brackets for the task of putting my new diamond racing 15s on the back of my 01. We'll have grinding all day I've ground so much off the bracket that I can clearly see the slide pins now.
I don't understand how you guys are making this work. I'm about positive the brackets are toast. I had to even cut down the slide pin to get the wheel to fit.
They are 15x10 with a 6.5 backspace. I knew I would have to grind but after all the research i seemed hopeful.
Not so much anymore. I'm sure I mist be doing something wrong
Anyone have any Input? I can't for a second believe the caliper will work at all. Ill include some photos
11 Second Club
I run that rim with zero issues. I also have OBS front calipers and Oakley brackets on the back of my truck.
1320 wheels sells brackets for the backs to fit 15's IIRC
https://www.performancetrucks.net/fo...ersion-532068/
I need those brackets.
Two calipers
Two rotors
And pads? Anything else I'm not aware of?
You had no problems right just bolt on and go?
11 Second Club
I'm about to scrap this whole project and start over. Seemed others had good luck just grinding but good lord that bracket is just not working.
Two calipers
Two rotors
Two calipers
Two rotors
Or you could swap to drum brakes and have no issue with fitment either
