ring gear spacer
I took it back and he pulled it apart and tack welded the collars on, ran great then broke the tacks, this time i let it go for to long and it wore a pattarn into my gears and it whines horrible.
I bought a Tru trac from Rons and a set of "oem" gears from a member here. Took the parts to have them installed, later on the mechanic calls and says he thinks the carrier is wrong. The ring and pinion are too loose and only way to get the proper back lash is to shim the carrier over to the passenger side .08 inch. that makes my brakes drag since it moves the axle shaft out.
I get part numbers from the boxes and call Rons, hes stumped and so is the installer, so am i.
We compare carriers, they are identical and correct, we then compare gears and the pinions are the same but the new oem ring gear is thinner than the us standard gear i had before.
I really needed my truck since it is my daily driver so i just put my old us standard gears in with the new tru trac and just deal with the whining.
Now im at the point of what do i do now. I have a set of OEM gears that are brand new but wont work, and i have no idea why. I dont want to go thru the hassle of trying to get a refund and send them back to the member.
The only thing i see to do now is buy a 3rd set of gears or a ring gear spacer to make my set work now.
Story over, WTF do i do?
I'm pretty sure that the 10 bolt Trutrac is designed for both the 8.5 and the 8.6" rears. You have to use the correct bearings depending on what rear the Trutrac is going into.
from eaton
Unit has large bearing journals that require special bearings when replacing O.E.M. small journal carriers.
Carrier Bearing Race OD 2.89"
Requires GM8.5-CBK-LH, GM8.5-CIK-LH or GM8.5-MOK-LH
http://www.rearendparts.com/product....cat=537&page=1
Master kit
http://www.rearendparts.com/product....1&cat=0&page=1
Carrier Bearing Race OD 3.06"
Use OEM, CBK-2, GM8.6-CIK or GM8.6-MOK
Master kit
http://www.rearendparts.com/product....9&cat=0&page=1
peace
Hog
from eaton
Master kit
Master kit
peace
Hog
from eaton
Master kit
Master kit
peace
Hog
from eaton
Master kit
Master kit
peace
Hog
Yes i know this, but when you shim it over a 1/4 inch it also shifts the axles over, therefore making the brakes drag.
