Ridetech Coil-overs Installed gmt-800
Old Nov 1, 2015 | 06:44 PM
  #331
twistedchevy's Avatar
Has anyone done this with qa1? I have DJM 4" LCAs and qa1s. Was wondering what spring rate and length anyone is running on a rcsb with 5.3
I have the qa1 501 double adjustable
Old Nov 1, 2015 | 07:46 PM
  #332
MWood's Avatar
Awesome! Thanks man. Thats a lot cheaper than amazon.
Old Nov 7, 2015 | 04:31 AM
  #333
06silverado2wd's Avatar
Registered User
will this set up work with 4 inch lift spindles?
Old Nov 7, 2015 | 05:15 PM
  #334
TheBeeblebrox's Avatar
A couple guys are running qa1's not sure what their rates/lengths are, maybe they will chime in.
I don't see why not, just measure first and order what works, might want to look into what the off-road guys are doing to get an idea.
Old Nov 8, 2015 | 07:22 PM
  #335
Registered User
Awesome! Thanks! What is the part number of those coil overs? Or what would work? I was looking at qa1 and ridetech.
Old Nov 8, 2015 | 07:37 PM
  #336
What you're going to have to do is measure your current ride hight from the shock tower to the LCA shock mount and find an applicable length shock to use.
On RideTech's site they have a stroke length (overall travel) with the compressed and extended lengths - ideally you want to be in the middle of those two with a slightly positive bias (so you don't bottom out).
In my case I'm running the Stud mount 6.3" stroke shock with a compressed/extended length of 12.63"/18.93" and my ride hight is about 15.5" iirc.
If you want to use a bearing mount with an adapter, this will change your measurements so keep that in mind too.
Old Nov 8, 2015 | 11:44 PM
  #337
mikeyjm1's Avatar
I have a lot more weight to control but for reference, I'm on a DS-301 with a 1300# 6" Eibach Spring. It feels perfect.
Old Nov 9, 2015 | 07:52 AM
  #338
Atomic's Avatar
I have a gauge for that
You have 4wd though, and most likely a shorter distance to fit the shock. 2wd setups generally need a longer shock.
Old Nov 9, 2015 | 11:52 PM
  #339
mikeyjm1's Avatar
I see that Atomic. More and more I think about cutting the shock towers and welding in some universals higher up on or from the frame rail to get a longer shock.
Old Feb 17, 2016 | 08:32 PM
  #340
MWood's Avatar
Sold my truck to Rocky Mount Motors in NC this weekend. Traded for a '03 Suburban 2500, 6.0, 4WD. Absolutely love this truck. Good luck to everyone in their coilover swaps.
