Replacing 10 bolts
Old Dec 4, 2013 | 06:18 PM
DAH32's Avatar
Default Replacing 10 bolts
What are the options to replace these weak 10 bolts in the 99 and up trucks?
Old Dec 4, 2013 | 06:20 PM
Ferocity02's Avatar
The best option is probably a 14 bolt, but the swap is fairly involved.
https://www.performancetrucks.net/fo...thread-467473/
Old Dec 4, 2013 | 06:30 PM
DAH32's Avatar
I'll check into it.
Is that going to be alot cheaper than getting a Ford 9" from someone like Moser for a 99 silverado?
Old Dec 4, 2013 | 06:32 PM
MechE's Avatar
how are the ten bolts weak? most of the guys on here have a 10 bolt
Old Dec 4, 2013 | 09:53 PM
02_Orange_D1SC's Avatar
Fastest D1 Procharged Truck
flaco got his truck in the 9s before the 10 bolt gave the ghost if you set them up right there a strong rearend
Old Dec 4, 2013 | 10:05 PM
kretty's Avatar
How would someone go about setting up a 10bolt for some real power?
Old Dec 4, 2013 | 10:22 PM
skeet's Avatar
what are you to referring as real power?
a detriot true track, yukon axles , good gear set, girdle, so forth will take plenty of punishment set the pinion and driveline up right and youre good i'd think for awhile
Old Dec 4, 2013 | 10:47 PM
Blown06's Avatar
8 Second Truck Club
Old Dec 4, 2013 | 10:53 PM
DAH32's Avatar
Running a Motive Gear set with a Duragrip locker. Pinion angle set at -6 with a t56. I run old school slapper bars.
Second rebuilt on a 100% street truck.
Old Dec 4, 2013 | 11:14 PM
AUTOT3K's Avatar
I run a Detroit locker, Richmond excel gear set and I also invested in a diff cover that has carrier bearing supports, just helps keep the gears from walking apart. I beat on mine regularily and with winter roads, theres plenty of times i'll be spinning on ice and suddenly find pavement and hook hard
here's that cover
**edit to add the date isn't correct on that haha, I just noticed that**
