Rear Sway Bar
Old Jan 14, 2007 | 05:44 PM
BlackLM7's Avatar
Default Rear Sway Bar
I've got an Addco rear sway bar that I'll be installing when I return from an upcoming 4 month deployment (military orders). Aside from the improved handling, are there any other benefits from using a rear sway bar? Will it:
-cure wheel hop?
-increase hauling and towing capacity?
-fix the "Chevy lean" in the rear?
Any info would be appreciated!!
Old Jan 14, 2007 | 10:23 PM
budhayes3's Avatar
PT's Slowest Truck
Improved cornerning as a result of less body roll is all you'll get from a sway bar. It' won't effect ride height, straight line traction, etc.
Old Jan 14, 2007 | 10:39 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Some say it helps with highway rear end sway.
Old Jan 15, 2007 | 10:41 AM
Zick's Avatar
Originally Posted by BlackLM7
-cure wheel hop? No
-increase hauling and towing capacity? No
-fix the "Chevy lean" in the rear? Doubt it
When I had one it did help with stability on the hwy.
Old Jan 15, 2007 | 11:51 AM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
That makes perfect sense to me -- and illustrates how sway bars may improve straight line stability. It's a function of reducing body movement and flex.
Old Jan 19, 2007 | 05:30 PM
GoldenVelvet's Avatar
I have that very same bar. E to the Z install! It will make a significant improvement in handling. You will notice it immediately.... But, shouldnt effect anything other then that.
chopperloco
Jul 10, 2016 10:45 PM
GXPJAY
Nov 5, 2015 06:49 AM
DONTH8
Jul 26, 2015 06:59 PM
Ketis
Jul 23, 2015 12:37 PM
maxspeed05V
Jul 19, 2015 07:08 PM
