rear end ratios? and trans problem?
Old Sep 16, 2010 | 12:01 PM
kalebm22's Avatar
Restricted User
Default rear end ratios? and trans problem?
i am looking at buying a 2000 gmc 1500 and i was wondering wat gear ratios this truck comes with.
also this truck seems to drive perfect until you get on it in first gear then it seems to not want to rev up and pull as good as second gear does. then it shifts pretty hard, what could cause this? second and third at wot feels good
Old Sep 16, 2010 | 12:21 PM
53bowtie's Avatar
If its 2wd it probably has 3.42 gears. If its 4wd it probably has 3.73 gears.
Old Sep 16, 2010 | 02:53 PM
kalebm22's Avatar
Restricted User
ok, it is 4x4. thanks for the info, now does anyone know about the weird trans problem?
Old Sep 16, 2010 | 04:59 PM
DV2000NJ's Avatar
13 Second Truck Club
For the gears look at the RPO sheet in the glove box.
GU6 = 3.42
GT4 = 3.73
GT5 = 4.10
Old Sep 16, 2010 | 05:11 PM
mhotrodscooter's Avatar
Doesn't sound like a trans problem. Might be fuel,plugged cats,bad plugs or wires, etc.
TAPyvehc93
Jul 23, 2017 10:54 PM
pjb1972
Sep 17, 2015 02:06 PM
So.cal Wrk Sled
Jul 26, 2015 12:10 AM
Ketis
Jul 23, 2015 12:37 PM
