Rear end problems
Old Jun 26, 2012 | 07:13 AM
  #21
Gadgetized's Avatar
I broke mine in properly 30 min cool downs for 500 miles. Pulled it apart, changed oil, checked all clearances, and they were dead on. No noise or problems here. Mine did get pretty warm the first drive. I wonder if yours got overheated the first run.
Also make sure the caps are tightened down when you are checking back lash. I would check this as soon as you pull the cover off to see what it is at.
Old Jul 6, 2012 | 10:45 AM
  #22
axisT6's Avatar
If you have the gears done again, make sure to record the settings:
Pinion Depth
Pinion Bearing Pre-Load
Backlash
Carrier bearing pre-load also has to be sufficient.
Look in the stickies, I did a gear install how-to that covers all of this. If your buddy does your gears again. Take the how-to and use it as check list.
Old Jul 7, 2012 | 10:43 AM
  #23
midnightbluS10's Avatar
Any updates? What did your buddy who installed them say? Did he fix his f*** up?
Old Jul 7, 2012 | 12:02 PM
  #24
blackedoutchevy22's Avatar
supposedly it was the gears weren't good but he's not gonna say he messed up. i got a set of 4.10 yukon gears and he put them in and i have no problems so far
Old Jul 7, 2012 | 06:17 PM
  #25
1FastBrick's Avatar
Custm2500's Rude Friend
Its entirely possible but highly unlikely... At least it is fixed and everything is good now.
Old Jul 7, 2012 | 08:30 PM
  #26
Yeahh thts what I thought I jus don't understand how the break in period can mess them up if they wernt hard enough. Like if you bought a brand new car ppl don't break those gears in you see where going with this? He might jus be covering for his mistake but it's all done and fixed so I guess I can't complain
pjb1972
Sep 17, 2015 02:06 PM
TimDave217
Aug 24, 2015 04:38 PM
vipergtrdj
Aug 6, 2015 10:19 PM
shupe
Aug 5, 2015 06:45 PM
Ketis
Jul 23, 2015 12:37 PM
