Rattling/Banging noise around bellhousing
My truck has developed a rattling noise at idle, loudest around the bellhousing. Seems to be a little louder if I remove the inspection plate on the bellhousing. So far it seems to run normal. I started hearing it last weekend although not as loud and I didn't think too much of it. I am preparing to move in a couple of weeks and was hauling stuff to a friends house for storage today and now it is noticeably louder. I'm only hearing it at idle and it's making a nice clunk when I shut the engine off.
Any ideas here?
Any ideas here?
Sounds like you may have developed a crack in your flexplate. You should pull the starter and inspect the plate as well as you can, but I suspect you'll have to unbolt the trans and converter and pull the whole thing back a couple inches so you can get a good look at it.
5 year bitches!
before you go buying a new flexplate do yoruself a favor and see if a converter bolt didnt back loose. this is common, it requires power and hard shifts to break a flexplate
Thank you all for the info. 3 loose converter bolts it was. All tightened back up now with some loctite to hold them in place. Funny that it took 3 years for them to loosen up noticeably enough to start making noise. Glad that's all it was.
