Question for you guys about my vibration issue?
Old Jul 20, 2009 | 06:57 PM
On20Z's Avatar
Default Question for you guys about my vibration issue?
Some of you guys know i posted about my dam bed shaking.So i replaced axles,pinion shims,uJoints,And it still shakes.Well today my wife took my truck and picked up some wheels/tires for my brother inlaw.She said that the thing didnt budge with weight on it and road beutiful.Is there something i could check in the leaf spring area that could be causing it to shake.I did by the truck used so im wondering if previous owner towed with it.I also adjusted my rear brakes last week and while it was on jack stands i started it and put it in drive and watched the whole bed shake but did notice the overload springs bouncing if that can help any of you point me in the right direction.
Old Jul 20, 2009 | 11:09 PM
built408's Avatar
I really don't understand your problem, so the truck has a vibration while driving and you can see the bed shake? How much is it lowered? Need alot more info.
Old Jul 21, 2009 | 07:03 PM
006rcsb's Avatar
sounds like something is binding in the rear end, but you just went through it when you swapped the axles.
Old Jul 22, 2009 | 05:28 PM
On20Z's Avatar
Its lowered 5/8.rear is a flip kit with stock block and shackle to give me the 8".When i put the axles in the vibration went away for about a week and now its worse.Pinion is shimmed with a 6* shim,u Joints are good.
Yeah i have no clue what is causing it to do this.
Old Jul 24, 2009 | 07:17 PM
Neverdone's Avatar
Have you checked to see if the tires/wheels are balanced correctly? Tire separation? Flat spot in the tread? Since they have been replaced, are the u-bolts tight?
Old Jul 24, 2009 | 11:11 PM
On20Z's Avatar
Trev,this is my 3rd set of wheels this year and same problem,U bolts are tight.Someone mentioned mabey spider gears,someday ill get it figured out.
Old Jul 25, 2009 | 11:29 AM
Neverdone's Avatar
Well that is a head scratcher for sure. With all the work you have already done, what else could it be but the rear end? Definitely let us know if/when you figure it out!
Good luck.
Go5.3tt06
Sep 12, 2015 09:29 AM
fillpot
Jul 26, 2015 07:21 PM
bgray
Jul 23, 2015 10:56 AM
lxcoupe
Jul 21, 2015 02:12 AM
GM-only
Jul 19, 2015 10:48 PM
