Pulling a tranny, any suggestions?
Old Feb 16, 2008 | 04:06 PM
formerly 20032wdsilverado (8/29/2011)
Default Pulling a tranny, any suggestions?
I am going to be pulling the tranny on my 87 gmc 1500, are there any problems that i might run into?
Thanks
Josh
Old Feb 16, 2008 | 06:51 PM
95ImpSS's Avatar
formerly 1BADC10 (12/14/2011)
Not unless you're anticipating any. 4-bolts on each side of frame for crossmember removal. Mount nut removal. Depending on trans type (TH-series or 700R4/4L60), you'll have bottom bellhousing cover bolts, converter bolts, bellhousing bolts, speedo cable, wire on pass side of trans, vac line (if equipped), dipstick removal, and drop it.
Old Feb 16, 2008 | 09:55 PM
doesnt get much easier that that
Old Feb 16, 2008 | 10:17 PM
i just didnt know if i would need to remove the rear engine mount and lower the entire assembly to get to the upper bolts or just get a f*cking long extension for the top bolts.
Old Feb 16, 2008 | 10:57 PM
95ImpSS's Avatar
You may want to invest in a 1/2" drive swivel & 12" extension to help with ratchet and socket.
Oobray
Jun 13, 2022 03:38 AM
ullose272
Aug 5, 2016 02:05 PM
pittman
Jan 19, 2016 07:06 AM
Fast86z
Aug 23, 2015 12:35 AM
Abuckeye
Aug 19, 2015 06:11 PM
