pulling tranny
Old Jul 9, 2005 | 08:38 PM
black4x4's Avatar
can I reuse the gasket onthe tranny pan and what is the torque specs on tranny pan and is there any other torque specs that I need to know
Old Jul 9, 2005 | 10:45 PM
BlownChevy's Avatar
blownerator
25 Year Member
Originally Posted by black4x4
how do i get the shifter linkage off the side of the tranny i already have it unbolted. and how do i undo the plug that hooks all the vss sencors on the t-case to one main wire?
You are better off un-bolting the entire electronic assembly, those plugs are notorious for breaking.
Old Jul 9, 2005 | 11:27 PM
KySilverado's Avatar
Amen brother. Wish I had unbolted the unit at the shift selector on the side of the tranny. I got the two plugs out but what a PITA. They had some type of clear something (glue?) on them. Had to pry them out with a screwdriver. Had to take an exacto knife and trim this stuff off to get them to plug back up.
Old Jul 9, 2005 | 11:28 PM
Should be able to reuse the gasket. I have twice. Just snug the bolts.
Old Jul 10, 2005 | 12:16 AM
BlownChevy's Avatar
blownerator
25 Year Member
Yeppers.....DO NOT overtighten those bolts!
Old Jul 10, 2005 | 01:55 AM
black4x4's Avatar
you guys just tauking about the black box on the driver side of the tranny?
Old Jul 10, 2005 | 07:18 AM
I am.
Just re-read your other question. Here are torque specs. I didn't torque anything. I guess the important one would be converter to flex plate torque. Good luck getting a torque wrench on them.Torque Specs
Old Jul 12, 2005 | 10:35 PM
black4x4's Avatar
Ok how do you guys seperate the tranny from the motor mine doesn't seem to want to budge.
Old Jul 13, 2005 | 02:06 AM
nightmarechevy's Avatar
Make sure the tq converter is unbolted from the flywheel and all of the tranny bolts are removed and pull back on the transmission. You may have to get a pry bar between the transmission and engine. If it does not come out very easily I would not try to force it, most likely there is still a bolt still holding it on or something.
Old Jul 13, 2005 | 10:32 AM
Bish's Avatar
I had a heck of a time getting mine out. After hours of pulling, prying, banging, spraying with penetrant, etc, I finally used a sling from the tranny to the trailer hitch to put quite a bit of tension on the trans. Then I rapped around the bellhousing and after about the 8th hit, it just pulled apart. I had LOTS of embedded rust around the alignment holes and the upper half of the bellhousing. I put anti-sieze on the alignment holes to make it easier if I have to pull it again.
Good Luck.
