Please help with upgrade!
Old Dec 3, 2010 | 01:59 PM
MstgKillr's Avatar
Default Please help with upgrade!
I have been searching for the last few days but I can’t seem to get the answers that I am looking for.
I have already purchased a Yank TTR3000 torque converter, Tru-Cool 40k transmission cooler, and the EAD Performance bracket/install kit.
Since I will be working on the transmission I figured I would install a shift kit too.
While reading about shift kits, I see that many people recommend to install some other parts while everthing is taken apart.
I am trying to put together an order but I want to make sure I go everything right the first time. Is there anything that I am missing or that I got wrong?
  • Transgo HD2 Reprogramming Kit. This seems to be the shift kit that most people recommend.
  • Corvette Servo Kit. Another common recommendation.
  • Aluminium front accumulator. I don’t know if I should go with the OEM or Sonnax.
  • Aluminium 1-2 accumulator. I read that I have to go with the OEM as the Sonnax pinless will not work with the Transgo HD2 kit.
  • Aluminium 3-4 accumulator. I don’t know if I should go with the OEM or the Sonnax.
  • Transgo seperator plate. I read that the Transgo HD2 kit comes with the gasket for this plate so I don’t need to purchase an additional one.
  • Transmission pan gasket. I read not to use the cork gasket with the Transgo HD2 kit.
  • Sonnax Torlon check ball 0.250” 10pc. I read to use these check ***** to prevent damage to the separator plate.
I am also confused about how many washers to use and what size hole to drill.
Old Dec 3, 2010 | 02:55 PM
Tootall's Avatar
there's a thread just like this one . . . ultimate valve body upgrade
Old Dec 3, 2010 | 04:46 PM
AJII's Avatar
Originally Posted by MstgKillr
[*]Aluminium 1-2 accumulator. I read that I have to go with the OEM as the Sonnax pinless will not work with the Transgo HD2 kit.
Where did you read this? I plan on adding a HD2 and the pinless 1-2 accumulator and have not read that they won't work together anywhere?
Thanks!
Gadgetized
Oct 22, 2015 09:06 AM
03sierraslt
14
Oct 9, 2015 05:53 AM
blackedoutchevy22
Oct 1, 2015 08:07 PM
redbird555
Sep 30, 2015 09:28 AM
sTNT971
Sep 26, 2015 06:27 AM
