Plannin on Eaton LSD install this weekend.
Ok here is what i want to do..
Replace the Gernade80 with the Eaton LSD, keeping the factory 3.42s. i have the shim kit and everything. do yall think it will be in spec with the factory shims? Im having trouble finding a Dial indicator right now.. So when i can get one of them ill be ready to go. |
i dont think so, when "axosT6" did mine, it took him about a good hour and a half to shim up the eaton right, just make sure you do everything right, when he installed mine, it looked pretty damn complicated, lots of little detailed things to remember
so did you just replace the diff, or you get new gears??
i know repalcing gears, that can take a good while! Im hoping the LSD wont be a big pain to install and get right. |
I used the factory shims and mine works fine. Make sure and take note of which one went on which side if your gonna use the factory shims.
oh i have already replaced the bearings on the gernade80.. we put everything back in like it came out, and its still good.
Did you use a Dial Indicator?? or just throw everything back in there? |
were is a good place to get a dial indicator??
summit, jegs, personally though, im a machinist so i can tell what a quality indicator is so i would buy a starrett, mitutoyo, or brown&sharpe. Also when you remove the caps that go over the carrier side baerings, mark which side they come off of and when you torque them use the criss cross method as if you were putting lug nuts on a 4 stud axle.
Since you're not touching the pinion gear you're going to have a much better time than someone replacing gears and carrier. Good luck!!!
I had to re-shim on the Hauler's when i did his, just measure your backlash before, and set it back to the same. Just remember, if you take .005" from one side, add .005" to the other side so your total shim thickness remains the same.
Since your probably only going to do this once buy a lower dollar dial indicator.
They work fine, they just don't last over the long haul in a machine shop. Try MSC or DGI Supply/DoAll, they will have high buch and import dial indicators. You will need a mangetic base to hold it properly un less you have something else to use. A mag base works best though. Below are some links, cheap stuff but they will work fine. http://www1.mscdirect.com/CGI/NNSRIT...MT4NO=13523283 http://www1.mscdirect.com/CGI/NNSRIT...MT4NO=13523310 Oh ya, when I did my Eaton it was within .001" with the factory shims. :) |
