Pinion Bearings
Well it looks like 270,000 miles is all my Pinion bearings wanted..
I noticed a vibration steadly getting worse at 70-75mph.
Took it to my buddys powertrain shop and sure nuff, the pinon is pretty loose
Its had 4 oil changes and new wheel bearings/diff bearings 115k miles ago but left the pinion bearings in it since they were still good.
So my options are to put a whole 3.23 rear end under it, or just put new pinion bearings in it...
or throw the 3.23 rear end under it so i can drop off my 3.42 rear and get them to freshen it up.
Well i think i can get my buddy to have it done with new pinion bearings for $80.
No go on the 3.23 rear. Its been sold. Some reason i think some high gears would be cool with the top end power.
So new bearings and we ready to rock
Mine has seen some pretty good stress towing heavy loads and a heavy foot.
And i didnt clean out the pumkin good when i put the diff bearings in.
Crawl under the truck and give the pinion a tug. If it moves any, they are goin.
trans fluid is definately worse. gear oil on my hands....trans fluid all over my back, shoulders and in my hair. usually mixed with some coolant. and if you are messing with a trans, it's usually burnt fluid. ugh.my next garage WILL have room for a lift.
