Pinion Angle
Old 03-02-2017, 11:35 AM
12 Second Club
ss4chad's Avatar
Default Pinion Angle
I dropped my 03 GMC (8' Long Bed) with a DJM 3" Lower A Arm in the front and 4" Shackle Relocation for the rear. Was fairly easy and was done over a weekend with with a friend, case of beer and a couple of cigars. Installed new shocks in all four corners and notched the frame in the rear with a DJM C notch for more suspension travel while hauling my car trailer.
I have a vibration at 75mph that gets progressively worse as you go faster. I measured the pinion angle and got 96 (maybe 97) on the rear end and 91 on the drive shaft.
So do I have -5 (or -6) as my pinion angle? Do I need to add shims under the forward part of the leaf spring to a -3 or -4 to get rid of that high speed vibration?
Thanks
Chad
Old 03-02-2017, 11:50 AM
FFDP's Avatar
You want to measure the angle of both the transmission housing end and the pinion itself.
It's much easier to use 0 as the starting point. So like the transmission is pointing 3 degrees down and the pinion is pointing 8 degrees up as a reference. You'd then shim the pinion to come down to match the transmission angle or be withing 1-2 degrees depending on application.
I use an el cheapo angle gauge from the hardware store that works great.
Old 03-02-2017, 12:22 PM
12 Second Club
ss4chad's Avatar
So I have to remove the driveshaft, do I then measure where the U-Joint attach point is, where the bolt holes are?
Chad
Old 03-02-2017, 12:27 PM
FFDP's Avatar
No, just measure it from the yoke on both ends.
Make sure both are pointing straight at the ground and measure. Use a mini block or wood or something square if you have to extend it down an inch to clear the driveshaft.
Like this.
Old 03-02-2017, 01:19 PM
12 Second Club
ss4chad's Avatar
Got it, thanks! I will see if I can get it on a lift at the local Oil Change Venue when I get the truck inspected. I will get back with ya then.
Chad
Old 03-02-2017, 03:01 PM
brandon6.0's Avatar
I thought the angles canceled each other out. say if your trans was -4 downward and rear was 6 upward u would have a pinion angle of 2 degrees. correct?? I always shoot for -3 for the rear-end if its race truck.
Old 03-02-2017, 05:12 PM
FFDP is correct. Stop measuring the driveshaft!!!! Whoever started that way of doing it should be shot.
Old 03-04-2017, 02:50 PM
11 Second Club
Mean Green z28's Avatar
Nobody was suggesting that, what are you smoking? haha
Old 03-06-2017, 11:09 AM
I accept flowers and chocolate as apology gestures.
Old 03-13-2017, 04:41 PM
12 Second Club
ss4chad's Avatar
Ok, I got -4 or -5 on the rear end
And -5 or -6 on the transmission
However, those readings were difficult to aquire, might be better to measure it again when I change the u-joints out this weekend and remove the driveshaft.
