Parking brake question..
Old May 21, 2014 | 11:49 AM
Slowest_1500's Avatar
Default Parking brake question..
I have a question regarding my e brake, it works perfect but when I dis-engage it, it'll slam up against the bottom of the dash so loud you can hear it from outside the truck..
I've set my friends e brake in his 2003 silverado and a couple at work in some 2007's and what not. I haven't found one other that does this..any body got a solution to this.
It's a little annoying, I've tried putting rubber to soften the blow but to no avail..
Old May 21, 2014 | 02:03 PM
gamble686's Avatar
My 2000 does the same thing. Hasn't ever bothered me before though.
Old May 21, 2014 | 03:41 PM
Chevy_King1500's Avatar
i would say 90% of them dont even work
Old May 22, 2014 | 08:13 AM
Crap..it's so annoying lol
Old May 22, 2014 | 09:21 PM
03silveradoLS's Avatar
my 03 silverado did the same thing, i just held my foot over it to slow it down before it hit.
Old May 22, 2014 | 10:43 PM
Cooder5.3's Avatar
My parking brake doesn't even work. You can push it to floor with no resistance.
Old May 23, 2014 | 01:32 AM
kelsey_canard's Avatar
Yea, mine is a 2003 and does it too. Could pull it for weight reduction I guess. Make a sweet parking brake pedal dampener
Old May 23, 2014 | 01:42 AM
_zebra's Avatar
makes children cry
just don't set it so hard. mine's a 5 speed, so i use it all the time. if i crank it to the floor, it sounds like it's gonna rip up through the dash when i release it - but if i set it just tight enough to hold, it only has a moderate thump when it releases.
Cooder - look at the cable that runs down the frame under the driver's door. it's probably just loose at the tensioning bracket where it pulls the cables that run to the rear
Old May 23, 2014 | 02:12 AM
mhotrodscooter's Avatar
Put your foot on it pull the release, and control the speed with your foot.. Problem solved
Old May 23, 2014 | 08:35 AM
GMC93's Avatar
Genius
