overload relocation?
Old Jan 13, 2013 | 06:21 PM
dirty_old_chevy's Avatar
Default overload relocation?
Alright, say I wanted to drop the *** end of my truck an inch or so, wanted to cut down spring wrap, and didnt want to degrade ride quality. What if I moved my overload to the top of my springpack? that would certainly limit the amount of springwrap and help weight transfer due to softer rear suspension. Has anyone tried this? I know its not the normal thing to do, but it may be worth a try.
Old Jan 13, 2013 | 06:31 PM
Beatdown Z's Avatar
Laid Back
That would lower it and make it ride like ****.
Old Jan 13, 2013 | 06:40 PM
Do you think it would be much worse than clamping the overload to the rest of the pack in its stock location?
AKlowriderZ71's Avatar
11 Second Hall Moniter
Old Jan 13, 2013 | 08:10 PM
Originally Posted by AKlowriderZ71
LOL! I'll bet you said the same thing about the first people to experiment with Ebay parts. It was just an idea, and I havent yet measured the arc of the bottom of the overload spring to see if it is less than the top spring. If it is going to try to "flatten" the rest of the spring pack a whole bunch, I dont really want to try it. I'm 5hrs away from home for work right now, and I cant really measure it right away, as I wont be home for at least a month.
Old Jan 13, 2013 | 09:16 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Why not use a drop shackle.
As mentioned, it will probably wont ride as good if you do what you suggested.
Old Jan 13, 2013 | 09:44 PM
Ya, I guess I should have mentioned spring wrap was the main thing I was trying to address. I guess I'll have to break down and build or buy a set of traction or slapper bars.
Old Jan 14, 2013 | 12:30 AM
A place in Anchorage has actually lowered some trucks with the method you described. I know of two personally, that came to me complaining of how their trucks rode after lowering. Needless to say, they ended up spending more money to have it done right.
There are a ton of good options out there to use, and lower your truck properly. Lots of good ways to correct wheel hop too. No need to reinvent the wheel here.
REDCYCLE13
Sep 15, 2016 03:02 PM
The_W
Oct 1, 2015 02:35 PM
lycominghunter
26
Sep 25, 2015 07:50 AM
97_ek
Sep 23, 2015 09:16 PM
