Other transfer cases with same dimensions as np149
I have an awd Silverado with a 4l80e and np149 and I’d like to find a transfer case that will use my existing rear driveshaft and allow proper 2wd for use on a dyno.
I have read about how to use the np149 on a dyno but I’m not interested in that method, I would prefer to swap to a 4x4 case.
Back when the truck was 4x4 i swapped from 60/4x4 to 80/awd in one go and used the stock driveshafts so I’m pretty sure the old transfer case wouldn’t work with the 80 and stock driveshaft.
If there is some site that lists dimensions of a bunch of cases that would be helpful too.
thanks
I swear I reused the stock driveshafts when swapping to 80e/149 which put in my head that the 149 is shorter than the stock case.
I have a spare and it’s 18” from flange to extent of seal.
