Ok something is totally fucked in rear end!!!
Old Jun 17, 2009 | 07:31 PM
  #31
okietech's Avatar
I would recomend yukon got mine for like 120 each or something from ( mods please edit if i cant say this) randys ring n pinion there advertised at like 25% Stronger than stock and ive never had any issues with mine.
Old Jun 17, 2009 | 08:05 PM
  #32
vanillagorilla's Avatar
Careful with what aftermarket set of axles you go with. They're not all just "better" than stock axles. Our rear ends are REALLY wide compared to ones most aftermarket axle companies deal with. So they'll probably just pull from an already heat treated and annealed blank, then cut the splines in. You want a manufacturer that will cut the splines, then anneal. Cutting the splines in after is ok if it's a +31 spline setup that has a bigger dia. to begin with. I couldn't believe how small the cross section of our axles were compared to a 12-bolt 30 spline, or a 31 spline 9" axles.
Did you determine that was the issue? It could be a bent or out of balance driveshaft. Hell, it could even be a tire/wheel. Did you check all those before messing with axles?
Old Jun 17, 2009 | 08:25 PM
  #33
On20Z's Avatar
Called them,For the nnbs they wanted 264 an axle,dont know what the difference is between 99-07 classic than 07+nnbs.
Checked all of that.Not the tire/wheels this is my 3rd set with same feeling.Had 2 mechanics diagnose the bent axles.Moser hooked me up with 285 for both+shipping.
Old Jun 17, 2009 | 08:34 PM
  #34
Mangled03gmc's Avatar
Baltimore Whore
MOSER IT IS. That is as good as it gets there..
Old Jun 17, 2009 | 11:14 PM
  #35
Good deal, but make sure the new axles slide in and out real easy. I was, and still am kind of convinced my housing is bent a little. A few hits with the t-brake is all it takes I guess. Anyway, if the axles don't slide in and out of the carrier real easy, then you may have a bent housing. It's not the most scientific test, but it's the best you can do short of taking it apart and putting it on a jig.
Old Jun 18, 2009 | 05:09 PM
  #36
On20Z's Avatar
What gear oil are you guys running.I was thinking of mabey getting Royal purple.Does ours take 90w?
Old Jun 19, 2009 | 04:25 PM
  #37
budhayes3's Avatar
PT's Slowest Truck
Synthetic 75w-90 for the G80, conventional 80w-90 for the TruTrac, no friction modifier necessary. Not sure what the Eaton LS calls for...
Old Jun 19, 2009 | 09:05 PM
  #38
On20Z's Avatar
I have none of those.stock 323 gears with pegleg.boooooo
Old Jun 20, 2009 | 02:56 PM
  #39
On20Z's Avatar
UPDATE!!!!!!!.
Axles are in,took it for a cruise and not one vibration,Still think driveshaft could use a speed balance cause everytime i bounced off the gov it seem to shutter.I also added bilstein front struts,trimmed bumpstop,doestch tech rear shocks and it handles so much better.To bad its raining again or id be cruising.Thank you guys for all your help,When i can get some time lined up ill look into tru trac/gears.
Old Jun 20, 2009 | 08:42 PM
  #40
andrew383's Avatar
traveling mod
glad you got it fixed
