Official A4 to M6 (T-56) Thread!
Old Dec 29, 2006 | 07:36 PM
  #41
Mater's Avatar
Originally Posted by Quik
ok started my swap the past couple days. what i found out is you can use a colum cover off a TB,envoy and etc to work for your cover. i used one off a TB
sorry son,that cover isnt off a TB!!
Old Dec 29, 2006 | 07:37 PM
  #42
Tootall's Avatar
great pics, but do you have more of the pedals mounted up?
Old Dec 29, 2006 | 07:40 PM
  #43
04GIBBS's Avatar
Default Cover for 5 speed
What truck do you think that cover came from?
Old Dec 29, 2006 | 08:49 PM
  #44
1TRUESS's Avatar
now my question is what is ppl doing for the safety switch on the clutch pedal?
also what is ppl doing with the two plugs that came off the column. shows to be a green and a black on each plug
Nothin! I have no idea what is still in my column? I gutted alot of it out and the truck still started so I left it alone.
ok heres a few other pics of the progress
this is a 2.5" hole saw drill thru the stock location using the dimple as the guide
I used a 2 3/8" hole saw. Does the 2 1/2" work alright?
I also unbolted the CC box and moved it out of my way as well as the fuse center, under the hood.
Old Dec 29, 2006 | 08:58 PM
  #45
1TRUESS's Avatar
Added this to post #21
Clutch pedal - GM PART # 15027983
Old Dec 29, 2006 | 11:16 PM
  #46
Quik's Avatar
5 year bitches!
came from a box that was labled Trailblazer/envoy
Old Dec 29, 2006 | 11:18 PM
  #47
Quik's Avatar
5 year bitches!
yea worked real well.
did you hook up the wires for the clutch pedal? also it seems to be that there is another bolt that is used to keep the pedal assmebly in place. its the one closest to the front of the dash. i didnt use it but on my pedal assembly it looks like it would be used since it has a bolt marking on it
Old Dec 29, 2006 | 11:19 PM
  #48
Quik's Avatar
5 year bitches!
it also looks like one off a s10. before i found that cover in Maters parts. i tried to mock up a s10 cover and it seemed to line up with a stock truck one pretty well
Old Dec 29, 2006 | 11:20 PM
  #49
Quik's Avatar
5 year bitches!
what do you need more of, i can take pics tomorrow if i get a chance to
Old Dec 30, 2006 | 07:09 AM
  #50
Mater's Avatar
s10's & F/S have the same covers,TB etc work also but have a hole in them for the INT lock with out power!
