Nv4500 going into 99 2 door Tahoe
Old Mar 1, 2012 | 07:54 PM
99tahoe2door's Avatar
Registered User
Default Nv4500 going into 99 2 door Tahoe
Hello all,
I'm new to this forum. I was told that you guys really know your stuff so here it goes. I have a 99 Tahoe 2 door 4x4 4L60E
I picked up a 96' Nv4500 out of a chevy 3500 truck. The trans is complete with the transfer case, yoke and PTO. For $500 bucks! I am planning to put it into my 99 2 door Tahoe manual shift transfer case. The Tahoe currently has a 4l60e in it. I know that I will need to have the ECM re flashed, Install master cylinder and pedal (provisions provided on the firewall) cut hole in floor board (provisions provided by GM), adapter u joints and wire up the neutral safety switch. I plan on eventually swapping out the cluster and column cover as well.
My question is: can a tuner use my ECM and just tune out the automatic shift points so that there will be no check engine codes?
Is there anyone else out there who has done a similar swap and been able to pass smog in California?
Thank you,
Kyle
Infernohoe
48
Oct 2, 2015 10:25 PM
BCraven1018
Oct 1, 2015 08:22 PM
mitchellmade
Sep 27, 2015 08:27 PM
project-pegasus
Sep 18, 2015 08:22 PM
RS/SS 4.8
Sep 17, 2015 09:17 PM
