New stall is stalling completely!
Old Sep 19, 2005 | 02:40 AM
RangerTJ's Avatar
Default New stall is stalling completely!
Heres my new problem with this setup. When I put the truck in gear after being shutdown, it acts like nuetral. I have to shift it to park and back into gear a couple of times, then it works as designed. Could my computer be causing this due to the stall converter, or is something more going on? All things in my sig were just done last week. For those who've been helping me out on this, thanks again.
Thanks,
Will
Old Sep 19, 2005 | 06:42 AM
Kano's Avatar
is the gear indicator on the display showing that you are in the correct gear?
if the indicator on the side of the tranny (the one with the plugins that wont come out, 2 boltholes, and attaches to the linkage) is out of adjustment
you could be showing you are in gear when your actually in neutral.
If so its a simple fix
Old Sep 19, 2005 | 07:20 AM
RangerTJ's Avatar
Yeah, it's showing the right gears. I think it's a computer issue if that is even possible.
Will
Old Sep 19, 2005 | 11:16 AM
Mort's Avatar
Cool
Did you check your fluid level? Is it OK? Check the electrical connections on the trans and make sure they are all good.
mitchellmade
Sep 27, 2015 08:25 PM
custm2500
Sep 8, 2015 05:53 PM
Cowboy Tom
Sep 5, 2015 04:29 PM
USMCvet0311
Sep 4, 2015 09:43 PM
subeone
Aug 19, 2015 07:44 AM
