need some help(4l60e)
Old May 3, 2016 | 03:04 PM
89sierra's Avatar
Default need some help(4l60e)
hey guys I am in need of some assistance. ill start of by saying I did a ls swap in an obs rcsb z71. I took the easy route. carbed and had my 700r4 beefed up. I shortly realized how much I dislike carbs. so I purchased a stand alone harness from nelson performance and am going back to fuel injected. I figured mite as well run a electronic transmission.
so I picked up a used 4l60e. I plan on having a shop go over it. but what internals should I have upgraded to make it a reliable transmission behind a lq9 with intake headers and tune?
this does not have to be a full blown race tranny.
so far my list consists of. what else should I add in
sonnax smart shell
sonnax servo and od servos
aluminum accumulators
Old May 3, 2016 | 11:00 PM
1FastBrick's Avatar
Custm2500's Rude Friend
look into using the Sonnax Performance Pack.
Old May 3, 2016 | 11:16 PM
Wolftrk99's Avatar
Save the hassle and expense and go with the sonnax performance pack and vette servo.... new reverse input drum with wide band. i have the z pack in my 3-4 others prefer the bw hi energy, rest of my clutches are alto red eagle, i also went with newer rollerized internals with 5 pinion planetaries and a beast sunshell... Just my 2¢
Old May 5, 2016 | 08:36 PM
89sierra's Avatar
thanks guys I will definitely be running the performance pack. the bw in the 3-4 clutches.
it seems from the research I have done the bw stays together better in the 3-4 then any other brand but for all the others it does not seem to matter
I have heard good/bad on the beast shell so if I can I am going to try out the smart shell
I try to start things out on a budget build but that snow ***** very quickly. lol
Old May 5, 2016 | 09:13 PM
Wolftrk99's Avatar
My budget build turned into something like $1600-1900 but i have a whole extra trans with nothing to build it for.... Lol
Old May 9, 2016 | 10:29 AM
89sierra's Avatar
try living in Canada where we got hosed for everything price wise
would you guys suggest a hardened output being a 4x4 and running larger tires?
Old May 9, 2016 | 10:33 AM
Wolftrk99's Avatar
Yes..... Its a good idea as is a hardened input shaft... Havent personally broken one yet but theres a first for everything!!!
Old May 10, 2016 | 12:27 AM
89sierra's Avatar
Thanks I know a couple guys around here that have snapped a couple but they seem more 2wd with big rims
Now here is my stupid question. The transmission I have is out of an 05. The computer I have tuned is a 411 set up for an 02. Is there any different in wiring internally or reasons those 2 would be incompatible?
Old May 10, 2016 | 12:56 AM
Wolftrk99's Avatar
No, they should be fine... The 4l60 didnt get the iss sensor until i want to say 07 or 08, iirc the wiring harness and solenoids are same up to 06-07 somewhere...
Old May 16, 2016 | 05:34 PM
89sierra's Avatar
another random question trying to gather parts and part numbers. does anyone happen to know the part # for the bw 29 element sprags and the carbon wideband?
