Need help with hurst roll control
Old Jan 20, 2006 | 04:48 PM
Dark Halo's Avatar
Default Need help with hurst roll control
Just wondering if anyone know how to intall a hurst roll control on a 02 chevy silverado? I have had the thing for over a year now and want to install it since I am putting my new set up in. I have never installed a roll control much less put one on a truck with ABS.
Old Jan 20, 2006 | 06:53 PM
On the older vehicles w/o ABS the front brakes tee off a common point usually at the proportioning valve, just have to tie into the brake line between the master cylinder and proportioning valve.
On ABS vehicle you need to have the roll control installed after the ABS unit, could cause some damage to ABS unit. On the NBS truck the ABS unit feeds each front wheel, no tee section. I think you might need to install 2 roll control unit, one on each front brake line. This might be best way because the ABS unit cost how much ($600) and roll control cost how much ($125)?
Old Jan 20, 2006 | 11:32 PM
i believe someone on here did it, but backwards, he would hit the rollcontrol and then the brake, it stopped flow to the rears instead of holdin pressure to the frotn, u hold the pedal and buttom then the gas
Old Jan 21, 2006 | 12:48 AM
NoChrome's Avatar
Thats how my camaro buddies do it, cant screw up abs that way.
Old Jan 21, 2006 | 08:40 AM
Dark Halo's Avatar
what happens if you don't hook it up backwards?
Old Jan 21, 2006 | 05:54 PM
Dark Halo's Avatar
also is there any way to install in like you would with out ABS?
Old Jan 29, 2006 | 03:55 PM
TURBO8's Avatar
I was thinking the same thing. I was going to install one on each front brake line. I was going to use the cheaper b&m ones thow. After the abs unit. Would this work? Or should I just hook one up to the rear and call it a day?
SloSVO
Nov 22, 2020 07:34 PM
Avalanche2002
Nov 30, 2015 07:31 AM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
