Need help choosing a stall-dyno graph included
Old Jul 9, 2007 | 09:12 AM
12secSS's Avatar
With what you posted, ideally for a lighter vehicle, a 4000 stall would be perfect. But since you have a heavier (truck) vehicle, you need to lower that stall speed consideration. The heavier weight will make the rated stall higher. I would say get at least a 3600 stall. Since you mention you want it for street manners and track (1/4 only?), I would suggest a 2.4 STR or more. Good luck!
The reason the TT3000 worked better is because it has a higher STR and the stall was probably around 3200-3300, the Vig in such a heavy vehicle was about a 3400-3500, but it has an STR of about 2.17. This is too loose for a heavy application and would results in sub-par 60'. Remember, Vig's rating are 400 rpms lower then where they stall, so the Vig3200 is actually a 3600, and when used in a truck it's true stall is more like 3800-3900.
Old Jul 10, 2007 | 07:17 PM
silent1's Avatar
Thanks for all the input. Yeah, I'm an ext. cab. It is my only vehicle so that's why I'd like to keep some street manners. I was originally thinking a 3600 and from what you guys are saying, this seems to be around what I want. I'll try it and post up the results. Thanks again!
Gadgetized
Oct 22, 2015 09:06 AM
carid
Oct 1, 2015 09:22 AM
redbird555
Sep 30, 2015 09:28 AM
sTNT971
Sep 26, 2015 04:22 PM
