Need help asap plz 4l60e trans
Old May 19, 2025 | 08:48 AM
Freddytheone's Avatar
Registered User
Originally Posted by RDF1
https://www.powdervalley.com/product...sZiXwml2ofvyey
Antilock Brake System
DTC C0055 or P0609 (With JF3 or JH6)
Diagnostic Instructions
* Perform the Diagnostic System Check - Vehicle prior to using this diagnostic procedure.
* Review Strategy Based Diagnosis for an overview of the diagnostic approach.
* Diagnostic Procedure Instructions provides an overview of each diagnostic category.
DTC Descriptors
DTC C0055 00
- Rear Wheel Speed Sensor Circuit
DTC C0055 5A
- Rear Wheel Speed Sensor Plausibility Failure
Diagnostic Fault Information
Circuit/System Description
The electronic control module (ECM) converts the data from the vehicle speed sensor to a 128K pulses/mile signal. The electronic brake control module (EBCM) uses the vehicle speed signal from the ECM in order to calculate the rear wheel speed.
Conditions for Running the DTC
C0055 00
* The ignition is ON.
* Ignition voltage is greater than 9.5 volts.
C0055 5A
* The brake pedal is not pressed.
* A DTC is not set for the other wheel speed circuit on the same axle.
Conditions for Setting the DTC
C0055 00
* An open is detected on the rear wheel speed sensor signal circuit.
* A short to ground is detected on the rear wheel speed sensor signal circuit.
* A short to voltage is detected on the rear wheel speed sensor signal circuit.
C0055 5A
The EBCM detects an erratic rear wheel speed signal.
Action Taken When the DTC Sets
* The EBCM disables the Antilock Brake System (ABS)/Traction Control System (TCS) for the duration of the ignition cycle.
* The electronic brake distribution (EBD) does not function optimally.
* The ABS indicator turns ON.
Conditions for Clearing the DTC
* The condition for setting the DTC is no longer present.
* The EBCM automatically clears the history DTC when a current DTC is not detected in 100 consecutive drive cycles.
Diagnostic Aids
If 2 or more wheel speed sensors are inoperative diagnose each wheel speed sensor individually.
An ECE 13 response may be required, after repairs are made, and DTCs are cleared, operate the vehicle at speeds greater than 13 km/h (8 mph) to complete the self test, and the EBCM will turn off the ABS indicator.
C0055 5A, 00
If the customer comments that the ABS indicator is ON only during moist environmental conditions: rain, snow, vehicle wash, etc., inspect the wheel speed sensor wiring for signs of water intrusion. Also, a condition may result in a stored history DTC C0055 , this DTC can set if a customer turns the ignition key from the RUN position to the ACCESSORY and leaves it for more than 1 second. The DTC may be stored in history due to a software condition in the EBCM, and no repairs are necessary. If the ABS indicator illuminates intermittently , clear all DTCs and simulate the effects of water intrusion by using the following procedure:
1. Spray the suspected area with a 5 percent saltwater solution. To create a 5 percent saltwater solution, add 2 teaspoons of salt to 8 fl oz of water (10 g of salt to 200 ml of water).
2. Test drive the vehicle over various road surfaces: bumps, turns, etc., above 40 km/h (25 mph) for at least 30 seconds.
3. Rinse the area thoroughly when completed.
Reference Information
Schematic Reference
Antilock Brake System Schematics (Electrical Diagrams)
Electrical Information Reference
* Circuit Testing
* Connector Repairs
* Testing for Intermittent Conditions and Poor Connections
* Wiring Repairs
Circuit/System Testing
1. Use a scan tool in order to clear the DTCs. Cycle the ignition to OFF and then start the engine. A current failure will set a DTC.
• If the DTC does not reset, go to Diagnostic Aids.
2. Turn OFF the ignition and disconnect the EBCM harness connector. At the EBCM harness connector terminal 31 W/JF3 or terminal 20 W/JH6, test for 10 volts on the vehicle speed signal circuit.
• If the voltage is below 10 volts, test for an open or short to ground on the vehicle speed signal circuit. If all circuits test normal, replace the EBCM.
3. Ignition ON, verify that a test lamp does not illuminates between the vehicle speed signal circuit terminal 31 W/JF3 or terminal 20 W/JH6 and ground.
• If the test lamp illuminate, test the vehicle speed signal circuit for a short to B+. If the circuit tests normal, replace the EBCM.
4. If all circuits test normal, replace the PCM.
Repair Instructions
Perform the Diagnostic Repair Verification after completing the diagnostic procedure.
Control Module References for EBCM/BPMV or PCM replacement, setup, and programming
pro multis · About Operation CHARM
thanks I’ll try that !!
schaefer
Mar 5, 2018 09:21 AM
ChevyTruck
Jan 22, 2014 12:25 PM
1BadAction
Apr 12, 2012 10:53 AM
eddie_da_chevy_guy
Aug 17, 2010 10:58 PM
trucksleeper
Nov 19, 2006 12:37 PM
