My tranny sounds like a half full water bottle
Old Feb 4, 2008 | 10:44 AM
00ChevyScott's Avatar
Wearin' da big hat
Default My tranny sounds like a half full water bottle
sloshing around. It's only under pretty hard acceleration/deceleration.
It doesnt last long, only a few seconds. But it sounds like a half full bottle of water sloshing around, could this be peices of metal floating around in my tranny? or is this normal.
I recently had a seal replaced on it because it was leaking. It drives fine except when I drive normal, but when I push it, its a bit sloppy on shifts.
**ask me any questions for info you might need**
106,000 miles
Old Feb 4, 2008 | 11:05 AM
054.8 silverado's Avatar
When's the last time you dropped the pan and changed the filter? Did you notice ayn metal then?
Is the fluid level ok?
Old Feb 4, 2008 | 04:37 PM
Wearin' da big hat
well about 3,000 miles ago, i had the tranny serviced and fluid changed because of a leaking seal. So I'm not sure about metal peices, the guy didnt say anything. But the next time i drive it, ill check the fluid level. it should be fine, havent noticed any leak spots
Old Feb 4, 2008 | 04:57 PM
BlackLM7's Avatar
I hear this same sloshing sound in my 1978 Camaro with a TH350 auto trans. It has been making this noise ever since it was rebuilt about 15,000 miles ago. There are no leaks and the fluid level is perfect. It seems like the sound is most noticeable after hard acceleration and when I first start the car up. I asked my trans builder about that noise a couple years ago and I forgot exactly what he said. All I really remember is the noise was "normal" and "not uncommon".
Old Feb 4, 2008 | 06:29 PM
Wearin' da big hat
I figured it was something common because my sisters fiance has almost the same truck and he said his does it too. Better safe than sorry.
Old Feb 4, 2008 | 06:44 PM
Truckshop's Avatar
a better exhaust and a properly adjusted volume **** will repair that noise.
Old Feb 4, 2008 | 10:55 PM
Wearin' da big hat
ive got a cutout (no muffler) so its plenty loud man haha
GXPJAY
Feb 13, 2022 08:15 AM
chvy=power
Sep 8, 2015 11:05 AM
dantheman1540
Jul 29, 2015 04:45 PM
