My rear end emits smelly air
VOILA...This is up to about 80mph at around the one minute mark of the video.
http://www.youtube.com/watch?v=Ttbm_jsgLuM
All that shows is that it's not the rear end or the axles...however, guess what!! With the rear end in the air and me sitting in the truck I still felt it, just not as violently which makes me think it's the Drive shaft. I'm a idiot that I didn't think of putting the camera underneath to record the DS.
check the u joint caps. might be best to disconnect the driveshaft from the rear end and make sure all the needles are in the cap and if one didnt fall down.. ive seen stuff similar to this happen..lower speeds though
Had this happen in an old mud truck, turned out to be the center pin in the rear gears was sliding down just a little and rubbing in the housing causing a slight bind everytime it made a round. It was at randomn speeds however, so I would vote for u joint or driveshaft.
