Mounted my Tru Cool 40k transmision cooler a little different.
Old Jul 25, 2009 | 10:25 AM
D_reks{5.3}'s Avatar
I agree, should have saved some cash and just got a smaller cooler and put it where its supose to go if you didnt want the temps to drop much, My trans temps never go over 125* in 100+* weather with my 40k..
Whatever works for you tho..
Old Jul 26, 2009 | 08:19 AM
bonj87's Avatar
Originally Posted by 616 of 933
what does it matter where he puts it its his truck. looks good. can you show the fans installed
it does matter. you CAN put it anywhere, but the most effecient place for it is in front of the radiator. TruCool's documentation says to put it there to be most efficient, in between the radiator and fans is the least effecient place for it.
Mine is in front of the radiator and works great.. i went on a 1000 mile trip on the highway, and my tranny temps were about 105 the whole trip
Old Jul 26, 2009 | 12:33 PM
built408's Avatar
Bunch of haters up in here. Looks good, clean install. Just make sure those lines are flared if your using rubber hose, to make sure they don't come off. I don't think your loosing much of anything from mounting it behind the radiator, and it gives alot more room for that front mount...
Old Jul 26, 2009 | 12:35 PM
built408's Avatar
105 is way too cool IMO. 150 range is what I like to see, did you bypass the radiator?
Old Jul 26, 2009 | 12:45 PM
bonj87's Avatar
bypass the radiator? you mean the stock transmission cooler? that was removed when the TruCool went in.
btw, im not hating, just givin my 2 cents worth. to each thier own.
here is a good example of what I was talking about.
Old Jul 26, 2009 | 02:55 PM
silver-mod-o's Avatar
Hunt&Fisherator
I bypassed my radiator in my cooler setup and used -6 braided hose... with a 32K cooler it runs fine... but I understand why you wanted to move it... I'd personally put it under the truck with a fan on it before I put it there though... let us know how it works after you stuff that intercooler in front if it...
Old Jul 26, 2009 | 03:02 PM
00Silv4.8's Avatar
obviously its going to be cooler without running through the radiator, but does it take significantly longer to heat it up?
Old Jul 26, 2009 | 03:07 PM
texx's Avatar
Looking at your set up, did you run factory lines to the added trans cooler? If you did what size AN were the factory lines?
Old Jul 26, 2009 | 05:20 PM
bonj87's Avatar
let me ask my installer about that.
the tranny heats up normallly, so does the motor, just doesnt get as hot.
Old Jul 26, 2009 | 08:18 PM
616 of 933's Avatar
Why has Sprayed99 ot MR P not commented
