Mini Tub
Old Mar 10, 2010 | 12:17 AM
  #21
LsxCody's Avatar
looks really good,keep up the good work
Old Mar 10, 2010 | 07:51 PM
  #22
thunderwagen's Avatar
I really like that setup. What fuel cell did you and racer go with?
Old Mar 11, 2010 | 12:16 PM
  #23
I'll be running a custom made one and mount the factory sending unit in it to allow my stock gas gauge to work. Upgraded pumps of course.
Old Mar 11, 2010 | 02:07 PM
  #24
Raffman's Avatar
I made mine, couldn't find the right size. GMracer I found out the hard way that the truck's fuel gauge is 40-240 ohm not the traditional chevy 0-90 ohm. I went with an Aeromotive A-1000 pump.
By the way anyone need a tube type 0-90 sender?
Old Mar 11, 2010 | 04:00 PM
  #25
fastlt1's Avatar
12 Second Club
Is the stock truck 240 ohms empty, 33 ohms full?
Old Mar 12, 2010 | 07:42 AM
  #26
Raffman's Avatar
no it's 250 ohm full , 40 ohm empty. Unfortunatly the aftermarket senders are reveresed from that! I'm working on a fix right now. I think if the resisters are reversed on the board it'll work............. I'll get back wid ya.
Old Mar 14, 2010 | 11:11 AM
  #27
Raffman's Avatar
Originally Posted by Raffman
no it's 250 ohm full , 40 ohm empty. Unfortunatly the aftermarket senders are reveresed from that! I'm using a tube type sender and working on a fix right now. I think if the resisters are reversed on the board it'll work............. I'll get back wid ya.
For the record, leave the resistors where they are. What needs to be done is move the neg terminal contact from the top of the board to the bottom with a jumper wire. One other thing to note is don't ground the aftermarket sender, theres two factory leads for the fuel gauge use them on the sender terminals and it doesn't seem to matter which is which it still works.
adunphy
Feb 22, 2016 06:38 PM
Sdailey
Sep 6, 2015 10:26 PM
So.cal Wrk Sled
Jul 26, 2015 12:10 AM
