Middle of 4L80 Swap Need Help
Old Mar 20, 2006 | 10:11 AM
  #21
Wilde Racing's Avatar
How do I change this text
I do and that sucks, I never knew you could get the adabter with two different bearings, I must have got lucky.
z7199, I really hope you installed that bearing! or yours came with it installed.
Old Mar 20, 2006 | 10:33 AM
  #22
z7199's Avatar
I am pretty sure it came installed (I know I didnt install it) I compared the two and the only diffrences I saw was the size of the input shaft hole I think I willl go to the dealer today and double check and see if it came with the bearing.
Old Mar 20, 2006 | 06:34 PM
  #23
I had to machine the speed engineering adaptor larger to accommodate the 26 pin needle bearing. Tthe adapter came with a different size needle bearing approximately 3mm smaller.
Old Mar 20, 2006 | 06:40 PM
  #24
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Why is it so hard for SE to make the part right?
Old Mar 20, 2006 | 09:09 PM
  #25
I think the mating shaft size in the T-case changed at the 02 model year. SE has been excellent in replacing the first adapter with the right one that gave me a fighting chance. Unfortunately in the end the part required further modifications that were fairly simple. The T case is back together and on the truck now. Onwards to better things!
Old Mar 22, 2006 | 06:55 AM
  #26
BigBlackAv's Avatar
I'm also in the middle of THEE swap...and it looks like a lot of others in here have done it too...can you post what everyone did for tuning....i have a custom dyno tune from Next level performance... but, they have not done a swap before and are unsure of what to do. I am considering buying hptuners but i can't get it quick enough. what are the other options?
Thanks!
Old Mar 22, 2006 | 11:25 PM
  #27
EFI live or HP tuners can actually get you going pretty quick. Lots of help and file sharing on this forum.
Good Luck
Old Mar 22, 2006 | 11:39 PM
  #28
Tell your tuner to take a 4l80e bin file and transer all your engine tables over.
Old Mar 23, 2006 | 12:02 AM
  #29
1slow01Z71's Avatar
Nelson handles that aspect of my truck quite well.
Old Mar 23, 2006 | 06:31 PM
  #30
BigBlackAv's Avatar
I just got HP Tuners (should be here tomorrow) where can i get a bin file?... I want to learn this software and do this myself.
Thanks!
