Maybe a stupid question... but
Old Jan 4, 2008 | 10:02 AM
KySilverado's Avatar
Default Maybe a stupid question... but
Is it okay to stand a tranmission up. The bell housing to engine surface as the base and the tailshaft pointing up. I have a new to me tranny and want to clean it and install servo and shift kit and don't have a stand.
Old Jan 4, 2008 | 10:17 AM
thunder550's Avatar
High on diesel fumes
My buddy just did it the opposite way (bellhousing up) to install a new pump and it was fine. I can't imagine why you wouldn't be able to. I've also seen trannies rotated every which way on stands to get to different parts of them. You should be fine.
Old Jan 4, 2008 | 10:59 AM
95ImpSS's Avatar
formerly 1BADC10 (12/14/2011)
Will be fine... if you're installing the shift kit, just use a light amount of assembly lube to keep the little parts within the valve body in place while you're working. You'll need to get to the pump at some point (if you're installing an HD2).
In a situation like that, something like I did would work for ya just fine... (see below).
Pics taken during last 60E rebuild
Completely rebuilt 60E w/ make-shift trans stand beside trans jack
Old Jan 4, 2008 | 06:13 PM
FLT's Avatar
FLT
FormerVendor
Ron I like your builders stand.
KY it is perfectly fine to put the trans on the bellhousing. Good luck with the shift kit install.
Old Jan 4, 2008 | 06:32 PM
Thanks for the input guys. Figured it was okay but you very seldom see them sitting like that.
HD2 kit and at least a Vetto servo going in as soon as I can get them here. Tore into the tranny a bit tonight, looks good and starting another thread with ID questions.
andrewlong
Nov 9, 2016 09:38 AM
andrewlong
Sep 8, 2015 10:25 PM
Roach Coach
Aug 30, 2015 10:06 PM
Aboss
Aug 11, 2015 09:05 AM
iregret
Jul 27, 2015 10:32 PM
