Master cylinder maybe
Old 12-26-2016, 07:24 PM
turbo_outlaw's Avatar
Default Master cylinder maybe
When I hit the brakes the truck initially pulls to the right but only for a second and the pedal goes more than half way down. If I let off the brake and immediately hit it again the pedal is up where it should be and I do not feel it pulling to the side anymore. Does this sound like the master cylinder?
Old 12-27-2016, 04:15 PM
Nope! One of the two slider pins on the driver side caliper was seized not allowing the caliper to slide back and forth.
Old 01-01-2017, 12:34 PM
Skip Fix's Avatar
Generally a pull will not be the MC-if it is bad either bad pedal pressure and no stopping . Pull is generally one side braking more than the other-either one side not working or one side too tight,binding,not releasing be it a caliper or drum.
Old 01-02-2017, 06:59 PM
The pedal going to the floor thing is what had me fooled.
