same combo your getting rid of too.....I really want a fun DD with a 6speed but if I can sell the 6l90 and put in my 4l80 and use the extra to put me that much closer to placing an order from kb
Got an LQ4, trade ya for that LY6 :)
Originally Posted by mitchellmade
(Post 4882014)
smokeshow your a little far or else I would let you beat on the ly6 till you got your motor back ... but i have two lq4s in the garage now and your build is what made me go get an ly6! "newer ecm is so much quicker and a better set up more compact something , something, something......) just got the ls9 cam in today from ferocity02 , awesome person to deal with by the way, so im going to tear apart that 07 4.8 for the front cover , lifters/guides, and valley cover. sending the heads over to head games to plane them real quick just enough to ensure they are straight . while dave is doing that I will yank off the pan check the bottom end (carfax on the truck says 82,000 miles) knock out the pistons , rods and crank . throw some arp bolts in the rods and double check them for roundness. Hopefully can leave the crank alone... give the block a quick hone toss on some new rings and replace bearings. hopefully heads will be done around the same time (not sure if I want to go to manley for valves since they are local )put new springs on set spring hieght assemble then stare at it because im not sure of what trans or harness( smokeshow) and by the way there is ly6 & l92 blocks on ebay kinda cheap right now brand new
$1700 from building a stroker? what are you building?
ly6 is better than a lq4 imo due to the rectangular port head,more flow.and yes im getting rid of the 6 speed just cause im going for more of a drag truck,other than that its badass...
that s what Im going to try to do ly6/6 speed i just really need 32 spline ..... any body want to trade 90 for a 80?
(Post 4882070)
It's going in an 08 so I have the 70e. I won't be putting in the 415 till i get the 80e and stall so I can have it all done at once and tuned. Its going to be my DD until I get my hands on a TDI jetta to get to work and back. |
6l90 - 4l80
alright on the fence about the 6l90 or 4l80 . if i break the 6l90 im screwed because they are not as readily available as 4l80es and alot more expensive . That and the ability to run a 149 transfer case . I already have a 32 spline input on the way , I think if I have one done for 34 spline that it would break because it would be to thin , then thought about respline the output shaft to 32 spline then it should be as strong as a 80 out put , right? advice?:bang:
update on this finally got awd transfer case from time2kill with 32 spline input shaft which is awesome but on the downside I got rid of the rcsb awhile ago so know I have a 32 spline 149 t case to sit around and collect dust
