lq4...4l65e question
i got a good deal on a 4l65e trans and i was told by the seller that i would need a ls1 type crank? they dont run for much so i decided to do it!
will i loose hp by switchin cranks? and is it harder then it sounds? is the 4l65e worth it?
thanks for any help
thanks for any help
sorry forgot that..its a 2000 6.0 engine out of a 2500 pick up...the tranny not sure what its from. pretty sure its from a 2wd truck because he had plans to install it in a ls1 i believe...the engine and tranny will be goin in a 87 s10. 2wd... with future plans to h/c set up and nitrous!
the 2000 6.0 has a longer crank and will not bolt up to the 4l65e. You would indeed have to change the crank out on the engine. Instead I would recommend installing a 4l80e transmission which will bolt right up and is far stronger than the 65e.
You are correct.
here is some info:
Crankshaft Replacement Caution For
1998-2005 GM 4.3, 4.8, 5.3, 5.7 & 6.0L Engines
The AERA Technical Committee offers the following information on crankshaft replacement caution for 1998-2003 GM 4.3, 4.8, 5.3, 5.7 and 6.0L engines. Design changes in the flywheel flange thickness have been made to some crankshafts used in the above-mentioned engines. This bulletin is being re-published with additional information.
The later crankshafts are shorter on the flywheel flange as seen in the listing below. These changes are due to the many different vehicle / transmission combinations being built by GM.
A flywheel spacer ring GM Part #12563532 and a longer bolt set GM Part #12563533 is required when using a thin flange crankshaft to replace a thick flange crankshaft. Also, if the crankshaft is being used in a vehicle, which is a standard shift application, you also need pilot bushing GM Part #12557583 or 12479894.
Note: GM part numbers correct as of 12-18-04.
Years Liters Casting # Trans Flange Thickness
1998 early 4.3L 236, 255 V-6 1.62 thick flange
1998+up 4.3L 236, 255 V-6 1.500 thick flange
1999-2000 4.8L 312 V-8 M/T 1.250 thick flange
1999-2000 6.0L 215 V-8 1.250 thick flange
1999-2005 4.8L 482 V-8 A/T .857 thick flange
2001-2005 4.8L 482 V-8 M/T .857 thick flange
1999-2005 5.3L 216 V-8 A/T .857 thick flange
1997-2005 5.7L 216 V-8 .857 thick flange
2001-2005 6.0L 216 V-8 .857 thick flange
All GEN III crankshafts used in Camaro, Corvette and Firebird have a .857 thick flange and also have a freeze plug installed at the bottom of the pilot shaft hole. The 4.8, 5.3 + 6.0L don?t have the freeze plug. The drilled hole thru the centerline of the 5.7L LS1 & LS6 crankshafts allows a path to balance crankcase pressure within the lower crankcase. Doing so has eliminated possible oil consumption when the engine is operated over 4800 RPM.
peace
Hog
You are correct.
here is some info:
peace
Hog
TAPyvehc93
Sep 12, 2015 08:19 PM
