Lowering a 2009 Sierra Denali, need help
Old Aug 4, 2010 | 09:46 PM
waylouderthanyou's Avatar
Default Lowering a 2009 Sierra Denali, need help
i have a 2009 sierra denali awd that i am trying to lower; 24'' lexani installed. so i'm searching high and low and found a belltech 641sp kit to lower my truck but i've been hearing that i might have problems. this truck as everyone knows, is an awd and if you lower it to much you'll run into drive train problems;at high speeds you will get vibration problems. i just want to lower this truck about 1.5'' of the tires. any help would be greatly appreciated. thanks guys.
Old Aug 4, 2010 | 10:32 PM
NORCAL STI's Avatar
IVE DONE tonssssssss of those trucks allready here locally. hit me up norcalss06@aol.com ill go thru it all with you. on guys trucks on 295 30 24 ive done 3/5 no issues at all. you can call me 24/7 also 415 519 2432 im actually lowering a 09 silvearado tonight so ill be up for a while.
Old Aug 4, 2010 | 10:49 PM
NORCAL STI's Avatar
btw the 641sp is not the kit you need.
All you need is the 641kit along with the rear street performance shocks its much cheaper and will do the trick.
Or you can do the djm 3/5 set up which is about the same price as the 641 kit. Anyways back to the silverado the guy gets off at 1130 and i got to finish this 6/8 drop on it before then.
gnasty1521
35
Nov 19, 2015 11:42 PM
chacho44
Aug 3, 2015 04:07 PM
chacho44
14
Jul 25, 2015 01:47 PM
Denali man
Jul 19, 2015 03:52 PM
chacho44
Jul 16, 2015 09:03 AM
