Lowered truck problems
Old Jan 12, 2013 | 09:20 PM
staticgmc03's Avatar
In for pics.. Confused also how your rubbing with that drop/tire combo..
Old Jan 13, 2013 | 12:45 PM
chutto's Avatar
The wheels are after market with an offset...having trouble posting pics
Old Jan 13, 2013 | 12:48 PM
fastnnuffrt's Avatar
Use phtobucket and use the IMG code
Old Jan 13, 2013 | 01:08 PM
03sierraslt's Avatar
If you have a smart phone then here is a how too on uploading pictures. Same basic theory applies with computer only slightly different.
https://www.performancetrucks.net/fo...mobile-511810/
Old Jan 13, 2013 | 01:29 PM
chutto's Avatar
Old Jan 13, 2013 | 01:32 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
That's not a "drop" problem. The wheels are the wrong offset. Way too much negative offset, and that makes them stick out past your fenders, and swing into your fenders when you turn.
FWIW, those wheels are intended for a lifted truck.
Old Jan 13, 2013 | 01:43 PM
chutto's Avatar
So nothing I can do tire wise?
Old Jan 13, 2013 | 01:46 PM
You could get some shorter tires, maybe a 275/45R20. Then your fender gap gets bigger, and you'll want to lower the truck more. Then it may end up rubbing again......
Old Jan 13, 2013 | 01:47 PM
chutto's Avatar
Thanks
Old Jan 13, 2013 | 03:39 PM
slammedsilvy's Avatar
The entire time I thought it was a rubbing problem in the back, since you mentioned leveling it.
Definitely offset as mentioned, you want a wheel with 30mm or more of offset. The more offset, the more the wheels sit in towards the center of the truck. Factory wheels usually have 31mm offset.
ferrellrooster
Mar 6, 2025 03:22 PM
wrb002
Aug 31, 2015 12:00 PM
92SS Wagon
14
Aug 4, 2015 06:42 PM
cams 98 silverado
Jul 31, 2015 07:36 AM
black6spdz
Jul 16, 2015 01:32 AM
