Lowered Rear with shock extensions
Guys,
I am having trouble with my shock extensions. I have the shock extensions on both mounts. One came with the DJM Rear lowering kit and the other is a Hotchkis (sp?) piece. Problem I have is that over time they loosen and will move upward with suspension travel, not allowing the shock to control rebound. It's almost like my shocks are too short and over time pulling them up and loose. The DJM kit actually came with a bolt that tied it into the rear end bracket and it looks like this bolt has been stretched. Is there a proper way to measure what lenght shock you need? Has anybody ever run into what I am described. What shocks are guys with 4-5 inch dropped rears running? |
wish i could help ya...but I have no clue. I only wanted to post to let ya know once you break 12 seconds in the 1/4 mile you DO realize no body is gonna help you anymore right? Espcially in the under 11.8. Hell look at Wilde Racing, he doesn't even post up anymore. LOL :D
first are your bolts grade 8? are you using the nuts that have the nylon lock ring on the end of them? if not use them. if not just weld them and bolt them. to measure shocks you will want to flex the suspension as much as you can and measure the compressed side and the side thats extended. then you will have to find a shock that will be long enough to for the suspension to extend and not over extend the shock and short enough for the suspension to compress with out bottoming out
Im running ground force nitro drop shocks for a 2-2 drop on a SS The parts numbers I think were 70042 and 70043. I believe the 70043 was for the rear? All the way extended they were around 4" shorter than the stock Z-71 shocks.
Originally Posted by mwalls54
(Post 3760846)
I'm just using what bolts came with the kit. They are G8 best I remember but no nylock. I had though about welding them since I don't think I will ever return the suspension to stock. Thanks for the reply. |
Originally Posted by WJ MARK
(Post 3760868)
I'll look the nitro part numbers up to see I can get dimensions on them. Thanks, |
1 Attachment(s)
Originally Posted by dewmanshu
(Post 3760837)
Go work on that truck of yours :engarde::jest: |
I had the same problem and just welded them up. Also im using doetsch tech shocks.
I think when I did mine, DJM said only the passenger side needed an extension. I was the told the extension was to correct the angle, not increase the suspension travel. I think I have 2 different shocks on my truck, 1 being 1" longer than the other.
I also welded mine because it kept on messing up the bolt. I will try to get a pic for ya. |
If the shock becomes fully extended the shock is going to pull on the attachment points(bolts/hanger bracet, etc.) You should measure the fully extended length of the OEM shock eye to eye. If you did a 4" drop the new shock should be that much shorter. The DJM comes with an extender on one side so that side would be shorter by the amount of drop minus the length of the entender.
