Lower Ball Joint Removal
Old Apr 10, 2007 | 06:02 AM
mzr3yt's Avatar
Default Lower Ball Joint Removal
When removing the lower ball joint, is there a special tool, like a puller that is supposed to be used? I think these new ball joints are straight, not tapered like old ones. Also, won't using a pickle fork tear up the boot?
Old Apr 10, 2007 | 09:37 AM
Bish's Avatar
I used a pickle fork and it tore the boot. I didn't care though because I was completely rebuilding the front end.
Old Apr 10, 2007 | 09:41 AM
Wilde Racing's Avatar
How do I change this text
Hit with a hammer
There is a tool to remove it from the a arm though...
Old Apr 10, 2007 | 10:44 AM
kawamatt2's Avatar
Old Apr 10, 2007 | 10:48 AM
Lurius's Avatar
To remove it from the LCA when me and my dad lowered my truck we used a few tools.. Mostly a cut off wheel, an air chisel(various attachments), and a BFH.
We cut an X in each of the rivets holding the ball joint in, then air chiseled the rivet heads off and would punch through with the chisel with a punch bit. Its a pain in the ***. Afterwards we used the 1/2" bolts from belltech to bolt new one on. I believe the bolts were red locktite'd and torqued to 65-85lbs.
-Lurius
Old Apr 10, 2007 | 12:22 PM
negativeswitches's Avatar
they are tapered (i've replaced them both)
ls1curt
Jan 5, 2016 11:33 AM
livefast1
Sep 25, 2015 07:31 PM
Superman09
Sep 25, 2015 05:55 AM
God Made Chevy
Sep 4, 2015 12:29 AM
