line lock finally installed (vid)
Old Apr 24, 2005 | 10:04 PM
Magic Chicken's Avatar
Originally Posted by lotsofhp
Just curious, why would you use nitrous on a burnout?
My engine didn't have enough power to spin the tires to do a good burnout. You can clearly see the difference between no nitrous and nitrous on the first 3 burnouts.
Wow that is a big diffrence . Oh and love the music!
Old Apr 24, 2005 | 10:08 PM
Dark Halo's Avatar
Originally Posted by Magic Chicken
I don't see why it wouldn't, they both do the same thing. I'm going to guess the 02 is in the same place as the 01, under the truck on the driver's side. It's tough to miss, it has 5 brake lines coming out of it.
which lines did you conect to it? and did you have to modify your lines in order to get it to work?
Old Apr 24, 2005 | 10:16 PM
There are 2 lines going into the ABS controller (from master cylinder) and 3 coming out (2 to the front brakes, 1 to the rear). You have to cut the rear brake line that is coming out of the ABS controller and flare a couple of nuts onto the ends to screw into the line lock. I paid a friend at a local shop $100 to do mine as I've never messed with brakes or flaring tools before.
Dark Halo's Avatar
I was also going to ask if you had any pictures? I am on dail up right now so a video would take to long. I just want to know how you installed it and see where an how it is installed. I have had my hurst roll control for about 7 months now and never knew how to or where to install it.
Old Apr 24, 2005 | 10:18 PM
I'll try to take some pics of it tomorrow for you.
Old Apr 24, 2005 | 10:24 PM
Dark Halo's Avatar
you can email them to drumpro01@hotmail.com Thanks alot.
Old Apr 24, 2005 | 10:26 PM
negativeswitches's Avatar
saweeeeeeeeett i always wanted link lok info but no one ever voices up thanks man!
Old Apr 25, 2005 | 08:51 AM
6gear's Avatar
Go ahead and post your pics, I would like to see them also
Old Apr 25, 2005 | 08:56 AM
6gear's Avatar
From past discussions, I installed mine in a somewhat controversial way. I used the Biondo line lock and installed it backwards on my rear brake line after the ABS controller. While engaged it disables the rear brakes (by not allowing fluid to flow to them) and still allows pedal control over your front brakes and I have not had any ABS or other issues.
So you still have to use your brake pedal but it only allows the front brakes to work? You push your line loc button before you hit the brakes and that way fluid does not go to the rear brakes.
I have a stick rig and this set up won't work for me.
