LAT Transmission Fluid - ever hear of it
Old May 21, 2013 | 08:37 AM
Choda's Avatar
Question LAT Transmission Fluid - ever hear of it
Have any of you heard of this stuff
Heavy Duty Synthetic Gear Oils | LAT Synthetic Racing Oils
I was told by a couple local guys (8 and 9 sec cars) that this is the best money can buy ( which is why its so expensive ). It keeps temps about 20 degrees colder than reg off the shelf fluid and keeps clutches strong for longer.
Its blue/purple color.
Old May 21, 2013 | 09:47 AM
Koots's Avatar
I don't personally think there is any need for that, unless you are pushing a weak transmission harder than necessary or are racing and need every little bit of help you can get. I don't know anything about that particular oil though, so I may be very wrong about it all.
Most transmission builders will tell you that regular ATF, like Dexron III or VI, Mercon/Type F or ATF+4. I'm running AMSOIL universal ATF in my TH350 and 4L80E only for it's cold flow properties up here in the Arctic. Otherwise it's not totally worth the money and isn't a solution to any problem you may have.
Old May 21, 2013 | 01:39 PM
Choda's Avatar
20 degress is where i say "WTF".
If its the same quality fluid as far as how it works in the trans and keeps everything lubed AND drops the temp 20*. This is an amazing product. I dont know if its true cause I havent tested it.
blownss27
Aug 14, 2020 08:27 AM
Noah Burns
Sep 13, 2015 09:28 AM
2004gibbstruck
Sep 7, 2015 06:05 PM
mayko
Sep 7, 2015 12:24 PM
