knocking/metal grinding noise from torque converter
Sounds kind of similar to an issue I had...
Cold start rattle - YouTube
My issue turned out to be the starter shield being loose and contacting the flexplate.
Chris
I thought about the starter and I've checked everything with that abd ita all good. When I originally had a shop look at it they said they unbolted the converter and pushed it away from the flywheel and started the truck and the noise was gone. So made me believe that something in the converter is bad.
When you are in park idling in gear the turbine inside the converter is spinning freely with the rest of the converter. Very little if any slip between the 2. When you drop it in gear you apply the forward clutches which stops the turbine from turning. This is typically when a converter noise will be the worse. Since you do not hear a big difference leads me to believe the noise is not converter related. But if you disconnected it and the noise went away, then that points back to the converter. Going to be interesting.... Good luck
Chris
Chris
Hey Chris
Went to drive the truck to my shop so I could start tearing into it, and not even 300ft from my driveway I lost all moving power. I stopped and crawled underneath and saw that all the torque converter to flywheel bolts, specifically the heads of the bolts were gone. Somehow they were broke off. The threads of the bolts are still in the torque converter, but the heads are all gone. Kind of odd since the other week we rechecked it all and put loctite on the bolts, tightened to the correct lbs per the book, there was also no play in the TC and flywheel. Maybe a bent/bad flywheel? Any ideas what would cause it to shred the bolts like that?
Luckily it did not damage anything internally, took a small piece off the side of the oil pan but didn't puncture the pan at all. I also have a oil pan that I can swap out if I notice more damage.
A little off topic but I got the transmission rebuilt with the Monster in a box stuff and the person who put it all together is a local guy who rebuilds trannys. I was just curious, the input shaft spins and the output shaft is pretty hard to spin. That is normal, right ?
