just making sure
Old Feb 6, 2008 | 06:19 PM
sickREDsierra's Avatar
Default just making sure
i just wanted to make sure before i order..... my truck is an 07 classic sierra
making sure---- 8.5" x 10 bolt x 30 spline
eaton posi part number --- 19559
does that sound right? my truck is the Work Truck model, i think they have the same rearend though? not sure.
thanks for any help.
Old Feb 6, 2008 | 07:12 PM
xlcooplx's Avatar
yours is an 8.6 30 spline 10bolt.
Old Feb 7, 2008 | 06:41 AM
thank you very much!
if i am not mistaken, one posi-unit will fit both 8.5" and 8.6" ....along with the ring/pinion set....right?
Old Feb 7, 2008 | 11:51 AM
1989k1500's Avatar
I think the only thing different is the carrier bearings. I know the eaton for the 8.5 will be fine in your 8.6 but you need the 8.6 bearings.
Old Feb 7, 2008 | 06:28 PM
KeukaZ71's Avatar
that sounds about right
Old Feb 7, 2008 | 07:17 PM
xlcooplx's Avatar
make sure the outter hub of the carrier fits the 8.6 bearing. the diameter of the hub should be 1.7812" The old 8.5 units outer hubs were 1.625"...thats a HUGE difference when installing....
Gadgetized
Aug 21, 2020 03:14 PM
GMCtrk
Dec 18, 2015 04:47 PM
lxcoupe
Aug 24, 2015 08:16 PM
Martin4_8
Aug 13, 2015 07:31 PM
steves86ta
Jul 28, 2015 10:21 AM
