jerking when slowing down
Old Sep 23, 2012 | 09:41 AM
LS1FREEK's Avatar
13 Second Truck Club
Probably to much desired airflow at idle when in gear. This is especially a problem when cammed.
Old Sep 25, 2012 | 08:42 PM
AndysC3's Avatar
so I lowered the Desired Airflow table by 3% and lowered the values in the 1000-1600 rpm tables in the throttle cracker. Seemed to work. Thanks for the advice.
Old Sep 28, 2012 | 12:11 PM
Denali08's Avatar
I started having a similar issue. I couldn't find Desired Airflow table on my HP Tuners.
Engine>Airflow>General Airflow.
Can you list how to get to the table?
Old Sep 28, 2012 | 12:23 PM
03sierraslt's Avatar
On your 08 it's called Final Airflow Min. I believe. On your 03 I believe it's called Running airflow? Cant remember.
Old Sep 28, 2012 | 01:28 PM
AndysC3's Avatar
I use efi Live. Not sure how hpt list it
Old Oct 19, 2012 | 03:18 AM
AndysC3's Avatar
This issue seems to be a torque converter issue. When the tow haul button is pushed in the converter stays unlocked. I pressed it in while it was bucking and it stopped. kinda likes its locking/unlocking constantly
Old Oct 19, 2012 | 04:41 AM
Denali08's Avatar
I think this could be the cause because my truck was perfect after the tune but later started to do that at certain speeds only.
Old Oct 19, 2012 | 12:11 PM
Ferocity02's Avatar
Mine does this when in gear, but it's a T56. However, the idea may be the same. My tires are basically directly connected to my crank shaft when in gear. Yours are too when your converter is locked. Therefore, it sounds like it may be a converter issue like you may have discovered with the tow/haul button.
Mine didn't buck before the cam, and does every now and then after the cam. It's on decel like you said. Mine does it around 1200-1600 rpms. I believe it can be mended with some tuning.
drummer0415
11
Oct 24, 2015 08:16 PM
Chevy305
Sep 28, 2015 09:21 PM
LARRY01Z28
28
Sep 28, 2015 07:54 AM
01silvy
Sep 26, 2015 10:20 PM
whitelazer
Sep 22, 2015 09:38 PM
