i snapped another output shaft today
Old Mar 21, 2010 | 11:09 PM
  #41
Spoolin's Avatar
GFYS and STFU
If someone did lose 1 second from the swap that is a very rare occurance. IMO there were other factors involved if he lost one whole second. Most I usually hear about is maybe .2 of a second. When I went to an 80e I sure as heck didn't lose all that much.
Old Mar 22, 2010 | 06:03 AM
  #42
zeake's Avatar
Turbo 6.0 + 4l60e = dead 4l60. 4l80 is the way to go. My truck is on jack stands waiting for a 4l80 after the turbo killed the level 5 4l65e
Old Mar 25, 2010 | 11:43 PM
  #43
stevenc's Avatar
Originally Posted by 454navyss
it may not be the output shaft afterall, idk, im not a transmission guru. the output shaft is not broken in the tailhousing but it definitely looks bent (not twisted). i started it in park, before i pulled the trans with the driveshaft unhooked at the axle and the driveshaft was spinning in park.....definiitely not supposed to do that. idk whats wrong with it but it doesnt work and the guy that built it is on vacation
It was spinning in park? Sounds like you broke the ring gear among other parts.
Old Mar 26, 2010 | 10:14 AM
  #44
fastnblu's Avatar
Originally Posted by 00ChevyScott
Tim, who knows if it will work or not. There are really too many factors to make an accurate assumption about that. It either will or won't, there isn't much to debate on that. You have a better chance of having the trans last longer with the 80e, but people break those trannys as well, so don't think you've got a 100% bulletproof tranny if you do decide to go 80e. You will have to take care when driving with both trannys with that kind of power, especially if you drive it on the street. Everyday driving seems to be harder on them than track only stuff, just because of all the miles you'll be putting on it.
It either will or won't? You must be great w/. true/ false questions.
You've a 50/50 chance you'll get it right.
Old Mar 27, 2010 | 02:07 AM
  #45
Originally Posted by TIM Z
I have to ask cuz im going need to address my trans soon.
Is a performabuilt or FLT top level 4L65E going to hold up to a cammed 6.0 that is going to be getting a front mount turbo?
Or should i get the 4L80E ?
Just want an easy trans out/ trans back in if possible. Getting tired of making stuff work.
I have a friend that has broken 3 4l65e performabuilt trans in his ecsb 6.0 with a front mount turbo
Old Mar 27, 2010 | 06:55 AM
  #46
LS1TRUCKGUY's Avatar
R
Old Mar 27, 2010 | 09:45 AM
  #47
D_reks{5.3}'s Avatar
And I had a friend with a 408 and 200 shot in an ECSB and his locally built 60e was awesome...
Its like valvesprings, No matter what brand, Dual springs or not, they all can/do break. Same with transmissions, No matter if you go built 60e, 65e, 70e, 80e they all break, some with only 300rwhp and others with 700+rwhp...
Its the luck of the draw.. just hope you get a good one.
Good luck with getting your trans fixed man.
SloSVO
Nov 22, 2020 07:34 PM
BROKE-aSS-BLAZER
Oct 13, 2017 03:50 PM
cheyenne383
Nov 13, 2015 09:24 AM
Cammed4ever
Sep 30, 2015 03:38 PM
StrokeTheLS
Sep 29, 2015 08:33 PM
