I need to know everything involved with a TH400 swap
Old Jul 13, 2006 | 01:01 PM
slowprocess's Avatar
Default I need to know everything involved with a TH400 swap
I'm sick of these F-ing 4l60e trannies. I need to know everything involved with swapping over to the 400. I'm no money man, so the 80e is out of the question at the time. The truck gets no long distance driving, so that is absolutely no factor. Thank you for any help
Old Jul 13, 2006 | 01:21 PM
silver-mod-o's Avatar
Hunt&Fisherator
as far as I know, you'll have to get a bell housing, drive-shaft, and some kind of compuer work.
Old Jul 13, 2006 | 01:27 PM
If that's all that is involved, I'll have this sucker running in no time!!!
Old Jul 13, 2006 | 01:58 PM
Hunt&Fisherator
well you'll have to tune out some of the tranny parameters completely. I honestly dont know what involved in that part of it but the harware issues will be easy to deal with... you may even have to fab up a cross member. which shouldnt be hard either. I know 2toneblown has a 400 in his truck.
Old Jul 13, 2006 | 02:06 PM
Dock Rocker's Avatar
blacksheep is running a 400 as well. The tranny is not electronic so you will have to fab a throttle cable bracket (there are lots of them aftermarket) to move the tv cable. Unless your truck is drive by wire you will be ok. Call Jackson powertrain and they will cut you a drive shaft. I think mine was about 200 bucks. You will also need a yoke that works with the trans and the output of the driveshaft.(ie corect # of splines)
Old Jul 13, 2006 | 02:09 PM
Everything seems easy enough other than the tuning issues. I'm going to give Allen a call and see what all would be involved in making the pcm work, if anything.
Old Jul 13, 2006 | 02:15 PM
Hunt&Fisherator
yeah, I have a TH400 at home I want to put in mine.. I just cant afford to lose OD... I take too many trips... a gear vendor is out of the question... too much $$$
Old Jul 13, 2006 | 06:35 PM
Rhino79's Avatar
9 Second Club
Here ya go, this might help.....http://www.4l60-e.com/#LS1%20Motor%2...20Transmission
Old Jul 13, 2006 | 08:18 PM
litreddevil's Avatar
Banned
you will need to get a new verter,drive shaft and tune out trans ,and make new cross member.
and realy a 350 t would work also just make sure you get a trans brake with it
Old Jul 13, 2006 | 10:50 PM
Bowtie70SS's Avatar
A turbo 400 is a mechanical trans that is vacuum modulated. No TV cable. It has a 1 wire 12 volt powered kickdown. You will need a trans, a dipstick and tube, a converter, a driveshaft yoke, inspection cover and it should bolt up. It is a one piece trans no seperate bell housing.
Dave
